📣 ANNOUNCEMENT: djay version 5.4.4 for macOS/iOS/Android
Hello everyone! I’m happy to report that we have another djay update for you. It is rolling out to the various app stores now and should be available to all users over the next several hours.
Please see details below:
IMPROVED
  • RANE ONE Mk2: improved connection stability
FIXED
  • Automix not working correctly when screen is off on macOS 26 Tahoe (macOS)
  • Display issue on iPhone 16/17 Pro and Pro Max with display zoom enabled (iOS)
  • Loading videos from Photos app (iOS)
NOTICE / REMINDER:
Thank you so much
Slak_Jaw
and the Dev Team:)
You’re welcome @eecy_cee
A post was split to a new topic: Key Match issue - macOS
This update V 5.4.4 brings some changes to Andreoid? from the description it appears that probably not .
Hi @Jaroslaw_Szkudlarek, referring to the Google Play Store release notes:
  • Fixed possible audio issues when using Crossfader FX tempo blend on older devices
  • Fixed double-tap to reset gain knob not working correctly
  • DDJ-GRV6: fixed stems FX resetting on song load
  • Various bug fixes and performance improvements.
I’m already lost:) this is against what V 5.4.3 contributes compared to 5.4.4. and by the way V 5.4.4 is not in the google play store
Sorry for the confusion @Jaroslaw_Szkudlarek. You are correct, looks like 5.4.3 is the latest version for Android and no 5.4.4 update.
To sum up, Djay v. 5.4 4 only for iOS, right? . ok, thanks for that.
For iOS and macOS only at the moment…
when will there be support for AlphaTheta new products like Opus Quad and AZ ? :frowning:
Djay V 5.4.4 est disponible ce jour sur le playstore
Djay V 5.4.4 is available today on the Playstore
Yes, 5.4.4 was released for Android today:
  • Various bug fixes and improvements
We also released 5.4.4 for Windows:
  • RANE ONE MK2: improved connection stability
Well it’s 5.4.4.4 on andreoid, I installed it personally wanted to correct the error with key lock włonczone caused crackling and swimming blunt
Can you please rephrase this? I’m not sure what you mean. Thanks!
2 posts were split to a new topic: Reloop Beatpad 2 Issues
Thanks to the djay crew
You’re welcome @Ralfi711
Those are standalone units, I don’t think there’s enough demand for them to make that happen
