Annoying problem with Rane Performer X djay pro
  • MacBook Pro M1Max
  • Sequoia 15.7.3:
  • Djay Pro 5.6.1
  • Rane Performer with firmware 1.3.0.13
  • On board effects for Rane Performer stems accapella/instrumental light does not stay correct when changing effects.
  1. Play a song and select accapella button on RP and select an onboard RP effect using effect button.
  2. Switch to another RP effect using another RP effect button. The song is still in accapella, but the accapella light on the RP goes off- which is in correct.
  3. Please see the video: Effect 1 is Echo Out, Effect 2 is Reverb, Effect 3 is Echo, Effect 4 is Stutter out
C) EXPECTED RESULTS:
  • The accapella light should not change by just selecting a new the RP onboard. The audio is still in accapella although the accapella light is changing.
D) ACTUAL RESULTS:
  • The RP accapella light is changing when the RP effect is changed
A post was merged into an existing topic: Rane Performer Manual FX issues
Merged with existing topic: Rane Performer Manual FX issues
