Any way to transfer metadata from Mac to Android?
  • Version of djay 5.3:
  • Hardware/controllers used Reloop Buddy):
Your question:
I have all my track analysis, cue points, etc set perfectly on a Mac, but would love to also get it on my Android.
As far as I understand, transferring metadata between different operating systems is not supported natively.
But are there any 3rd party sollutions, or even manual hacks, that would make this possible?
Hi @Blammo, this is not currently possible within djay. Also, I do not believe any 3rd party apps currently support Android. The only option that might be possible is Lexicon.
