Thanks for the additional info @MRDJ
It’s still happening on my iPad
Prior to the error code appearing, what are you doing?
Analyzing a tracklist
…and the size of that was?
A few hundred but it’s only an issue on the iPad. It used to work on the iPad and it works on my MacBook since the last update, although it’s very slow. While I had this problem of not being able to load or analyze tracks for a while, I could still use Apple Music on my MacBook.
Thanks for the info @Andreas_Haase1. Can you please test with smaller playlists to see if you get the same error? Thanks!
On my iMAC (Big Sur Ver 11.7.10.) Im actually using DJPro 5.1.3 and it happens in this update as well. Mostly when using Automix. The matched songs start swapping around. The Current Playing and the Up Next keep rapidly changing to different songs.Then the Error Code 429 appears. If I stop it and manually load a track and turn on Automix again the 429 error comes back. For me this is happening using my Apple Music playlists only I haven’t tried anything else yet.
