Thanks for confirming @NowhereMan73
New Apple Music-playlists still not showing up in djay. Pls continue to investigate issue, thx.
Hi @gtkriz, welcome to the Community! Thanks for sharing. Weâll continue investigating this then.
Hello again everyone, it looks like there may be a workaround to âre-syncâ the playlists created during the period when the issue was occurring (as those playlists may still not be reflected correctly.)
- Rename the affected playlist in Apple Music outside djay, and restart djay.
Did work for me⌠thank you!
Youâre welcome @gtkriz. Thanks for confirming
I too started having this issue. None of the workarounds mentioned have worked for me, but I was able to find a newly created playlist tucked away in the âhomeâ section under ârecently played,â though it still doesnât show up in the list of all the playlists. Strange.
Hi @Timtimtimtimtim, welcome to the Community! Sorry to hear youâre experiencing this issue. If you tried all the workarounds above, I unfortunately have no additional suggestions for you to try.
Thanks for reaching out, Slak_Jaw. I hope my comment provides another workaround for those facing the same issue. If you canât find a recently created playlist, try scrolling down to âRecently Playedâ in the Apple Music home section. It might appear there. In my screenshot, the playlist titled âAAA MIXXYâ is missing from the playlist section but is visible under âRecently Playedâ in the home section.
Youâre welcome @Timtimtimtimtim. Thanks for sharing this.
