Is there an easy way to assign audio effects instead of sound effects into the sampler on: dj2go2 controller?
Note: This conversation was created from a reply on: If you have problems mapping your controller, please like this post!!!.
Hi Afshin,
Thank you for your post.
Which audio effects do you want to use and which djay version and device are you using?
