Audio hickup (beat skips) when activating microphone
Audio skips (hickups) on the playing deck → Master/mixer output
  • Device model: Apple Mac mini M2 Pro & Macbook Air M3
  • Version of operating system: macOS 26.5.1
  • Version of djay: 5.6.5
  • Hardware/controllers used : NI Traktor Kontrol S3 with and without
When activating the microphone using the on-screen (slide)button or on an external controller, the audio skips (hickups) on the playing deck
Happens everytime, doesn’t matter if an external controller is connected or if I use Djay stand alone and on both my MacOS computers.
Hi @HansDNL, thanks for the setup and issue details. Since this sounds repeatable, can you please capture and share a short screen recording of the issue to help clarify what’s happening? Thanks!
Please find attached a screen-recording I made. You can hear beat (tempo) skips and clicks when the mic is switched on and off. (Please listen with headphones or “real” speakers.)
The recording is made on my Macbook Air M3 with no external controller or external soundcard attached, as stand-alone as possible
Please advice, thanks.
Thanks for the video @HansDNL. Can you please confirm what you are using for a microphone since you have no controller our external soundcard connected?
The microphone selected is/was the internal mic in the Macbook Air M3 but it doesn’t matter if I select the mic input on the Traktor Kontrol S3 (when the controller is connected) or my Komplete Audio 6, the skips/hickups are the same.
Thanks for the additional info @HansDNL. Do you know if this is a new issue with 5.6.5 or if it was also present in previous versions?
I was able to reproduce this on my setup and have passed it onto our engineering team for further review. I’ll report back when I have more news. Thanks!
Unfortunately I don’t know if the issue was present before 5.6.5. Great to hear that you were able to reproduce and I look forward to a fix (and/or more info). Thanks for your time.
No problem. You’re welcome @HansDNL
Maybe useful extra info: The issue is not present in the iPad version. All is fine there.
  1. Device model: Apple iPad (9th generation)
  2. Version of operating system: iPadOS 26.5
  3. Version of djay: 5.6.5
  4. Hardware/controllers used : NI Traktor Kontrol S3 (connected via Apple Lightning to USB 3 Camera Adapter)
This is helpful. Thanks for sharing @HansDNL
Hi again @HansDNL, our engineering team was able to reproduce this issue and they are investigating further. I’ll share more news when I have it. Thanks!
The issue is still there in version 5.6.6
You are offcourse aware of that but just as info for others that follow this.
Thanks for the follow up @HansDNL. Yes, I can confirm the team is still working on this.
Just updated to version 5.6.7 and the issue is still there.
Thanks for the follow up @HansDNL. Our engineering team is still working on this one.
Just updated to version 5.6.8 and the issue is still there.
Hi again @HansDNL, a fix for your issue was not a part of the 5.6.8 update. When this is resolved, I will let you know.
And I keep reporting :wink:
In my opinion a microphone is a core feature in a dj application. Every serious controller has at least one input for it, it should just work (and it did many versions ago)
Thanks @HansDNL
Update: The problem is worse in version 5.6.8
In the previous few versions you could switch on/off the microphone on top of a beat (timing it just right) and it was often unnoticeable but now the skips/clicks are always there, the jumps became wider so to speak.
