@Djdash @Slak_Jaw I appreciate you helping. Pls listen at your leisure, no rush on my end. Here is the SC link, are the time stamps w/ track ID plus notes on my thoughts. Feel free to inform me if I’m using terminology incorrectly. Any bits of wisdom I truly appreciate!
Time stamps:
06:14 tracks:
safe from harm luca cassini & true beat x Lockdown brian cua remix
Are the low frequencies too high? Does it distort the music? Is distort the right term? Do you want peaks and valleys or do you want consistency? I imagine consistency in frequencies sounds better that some stronger than others.
10:14 tracks:
Lockdown x Move Your Body Paul Goodyear Remix
The low frequencies during this transition make the transition seem so sudden to me. It’s not a smooth transition because one track seems to have louder bass.
15:59 tracks:
move your body x up to you instrumental Bruno kauffman
The low frequencies sound strong again in this incoming track.
21:51 tracks:
Up to you instrumental bruno kauffman x fresh drums
The next track fresh drums has louder low frequencies again.
25:52 tracks
Fresh drums x that’s it
Does this transition sound smooth? I feel like the bass is off again.
31:10-31:20 tracks
that’s it x noises
The tracks were out of sync. Every now and then, the dj app will do this. Idk why.
36:06 tracks
noises x feeling like tribal mix
Fell out of sync again for a second or two.
37:36-37:40 tracks
feeling like tribal mix x me tienes harta
Out of sync
At the end it falls out of sync pretty bad, that was my mixing
I just ran with it.
