Recent bug, not anymore to map the respective Deck GAIN, worked for years before, the problem is software, I already try with different MIDI controller, that is the lonely fonction not anymore mappable. The bug is from the update 5.2.9 to 5.3 (still not working on 5.3.1)
on my MACBOOK Pro M1-MAX with Sequoia 15.3.2
Summary of the issue:
How to reproduce the issue:
