Thanks for the additional info @Christophroar. Please provide your drive format not drive type.
https://help.algoriddim.com/hc/en-us/articles/23070080061212-Using-OneLibrary-in-djay
The drive is formatted as exFAT, the only way to get it to work is to format the drive each time which isn’t ideal.
Thanks @Christophroar,
I ran some tests with multiple drives now (reformatting and naming) and it still fails to read the library and shows the disabled allow access on those drives after ejecting and reinserting the drive.
Both SSD and usb thumb drives produce this bug.
I have tried the ssd and usb drive on pc and iOS and they work flawlessly, the OneLibrary loading issues appears to only be affecting MacOS.
This is exactly the same for me, except when renaming the drive I am able to access it until either djay is closed and reopened, or the drive is ejected and then mounted again. I have also found that when renaming the drive, if the name has previously been used it cannot be used again.
Yep, using your method was the only way I could get it to work on MacOS (which was such a pain I unfortunately just gave up and closed Djay)
Thanks for the additional information and troubleshooting @Christophroar and @samwoodhead. I’m still not able to reproduce this issue so I have escalated it to our engineering team for further analysis. I’ll report back when I have more news.
Hi again @Christophroar and @samwoodhead, please collect a log output from Console.app on macOS while replicating the issue in djay. NOTE: Make sure your user profile has Administrator Privileges.
I have that problem on macOS too. It works fine on Windows.
Hi @OmarGonzalez, please collect a log output from Console.app on macOS while replicating the issue in djay. NOTE: Make sure your user profile has Administrator Privileges.
Any update on this issue? @Slak_Jaw
Hi @Christophroar, our engineering team doesn’t work over the weekends so no updates yet. I’ll share news here when I have it though. Thanks!
Are you formatting the USB with a Master Boot Record?
FAT32 + Master Boot Record is generally considered the most compatible/reliable.
I’ve tried all the formatting options and have had no success.
I even tried a brand new Sandisk Extreme Pro USB drive, this issue only happens on MacOS and Djay.
Also another issue I’ve noticed is that the drive in OneLibrary will stay in the list even when ejected from Finder, trying to eject from Djay will give the “This drive is in use and can’t be ejected.” error message.
On Windows, iOS (iPhone) and iOS (iPad) OneLibrary works instantly without any issue.
Thanks for the suggestion @Michael_Wisniewski.
Thanks for the additional info @Christophroar. Please use the USB Eject button within djay instead of the eject options external to djay.
Thanks for the screenshot @Christophroar - this is very helpful.
