Can't access local music when switching to portrait
  • Device model M1 iPad Pro 2TB:
  • Version of operating system iPadOS 18.1.1:
  • Version of djay 5.3:
  • Hardware/controllers used none:
Summary of the issue:
Started testing 5.3…
Could not access local music in playlists in portrait mode, had to switch to another source then back to fix it.
After using mix now button, and the mix completes. the track that is now playing will pause for a split second.
How to reproduce the issue:
Issue 1, seems to happen after you rotate the iPad from landscape to portrait mode
Issue 2, I have come across it three times now. Seems to happen most often when using the crossfader FX on your first mix after starting the app.
Hi @Stevie_Ray, sorry to hear you’re experiencing this issue. Thanks for the details about your setup and the issue - this is very helpful!
To help us troubleshoot this further, can you please try to capture a short video of the issue and upload it here? Please note the maximum file size is 200MB, so if your video is larger than that, you’ll need to upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the file here. Thanks!
Here is video of the library issue
RPReplay_Final1744159369|video
Thanks for the video @Stevie_Ray. This is very helpful. I was not able to replicate this on my iPad, so I’ve forwarded it to engineering to see if they can reproduce the problem and offer any suggestion.
Hi again @Stevie_Ray, engineering was able to replicate this issue and is investigating further. I’ll report back here when I have more news. Thanks!
Hi again @Stevie_Ray, engineering has identified the issue and is working on a fix. This should be addressed in an upcoming update (likely 5.3.2). Thanks!
Thanks @Slak_Jaw I am still trying to replicate the stutter. I do have a feature request too.
I would love full media access in portrait mode like this. Sort of
Hi @Stevie_Ray, this has already been suggested. Please vote over there:
