Can't enable Crossfader FX
Since I updated to version 5.2.11033.0, I can’t enable Crossfader FX. Yesterday, I could do it with the previous version.
  • Device model ASUS TUF F15:
  • Version of operating system Windows 10:
  • Version of djay 5.2.11033.0:
  • Hardware/controllers used Pioneer DDJ_SB2:
Hi @Chirro_Peres, thanks for the details about your setup and the issue. I was unable to reproduce this issue on my Windows setup. CFX is working as expected. Can you please try to capture a short video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Hello, since yesterday my DJay Pro 5.2 is lagging non-stop. I use it on my Windows computer and when i try to activate the Crossfader FX to synchronize with the Next music does not work… I have deleted and reinstalled the app several times but the problem is still there.
Hi @Lukitoz, I’ve merged your new topic with this existing one. In the future, please use Search before creating new topics. Thanks.
Also, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Since this sounds repeatable, can you please try to capture a short video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Hi again @Chirro_Peres and @Lukitoz can you please confirm if this issue is with a specific CFX type or with all types? For example, can you please try selecting a non-Neural Mix CFX type like EQ, Filter or Fade? Thanks!
This issue happens to me with any type of effect, including Fade and Filter. It occurs on two completely different computers: my home laptop running Windows 10, where I’m logged in with my Pro account, and my work desktop computer running Windows 11, where I’m not logged in with any account.
Every time I try to activate Crossfader FX, the effects window closes, and Crossfader FX does not activate.
This has been happening since I updated to the latest version.
This morning, at work, I was using the previous version, and I confirmed that Crossfader FX worked correctly. I updated to the latest version, and now it no longer works.
Previous version:
Current version:
I’m surprised that more Windows users aren’t reporting the same issue.
Thanks for the additional info and screenshots @Chirro_Peres. Does this happen with and without your DJ controller connected?
Yes. At home I have Pioneer DDJ-SB2 pluged in, at work I haven’t any DJ controller.
  • Device model * PC Lenovo
  • Version of operating system *Win 11
  • Version of djay *Latest
  • Hardware/controllers used Mixtrack Platinium:
    Summary of the issue: No post FX on stems
Hey guys, Hello, Crossfader FX does not stay locked anymore, be carreful, new hidding bug has been discovered, ghost in the machine!!!:star_struck:
hi @JustineB, please use search before creating new topics. I have merged your new topic with this existing one. This is a known issue, thanks for sharing.
Hi, I have exactly the same problem as @Chirro_Peres . Before creating this Topic, I was on Windows 10. Then I downloaded Windows 11 because i thought it was a compatibility problem with the Computer and the App. But after lauching DJay i see that the problem is still there.
DJay version : 5.2. 11033.0
Windows version 11
Computer : Lenovo LAPTOP-5QVOTMTO
DJ Controller : DDJ-200
Thanks for the additional details @Lukitoz. Does this issue also exist when your controller is not connected?
Yes both times. Connected and not connected…
Hello everyone. Engineering was able to identify the issue. It should be addressed in the next djay update. Thanks!
Ok. Thanks for your support.
You’re welcome @Chirro_Peres
Do you know when the next update will come?
Unfortunately, I do not.
Hello, was there a way to download the previous Version of DJAY Pro ? Waiting for a new update ?
Hi @Lukitoz, there is no way to download the previous version. Do you have a full system backup or saved restore point of your laptop that you can revert to?
