Config option: Don't auto-play cue points
As a side point to the Config profiles suggestion, but a separate piece of functionality…
Would it be possible to set it so that the 8 coloured cue point buttons allowed you to skip to a position in the track, but not auto play it. You can do this with the normal cue button, but it seems not the 8 coloured pads.
Hopefully a simple setting to add - same as the cue button, a slider that said ‘auto play coloured cues’ (you’ll have a better term for them!) that is on by default, but I can turn off if I want to …
