- Version of operating system (e.g. macOS 15.6.1 ):
- Hardware/controllers used (e.g. Pioneer DDJ-FLX4):
Your question:
On two separate Mac Book pro’s both running Sequoia 15.6.1 (24G90) and DJ Pro 5.4.2 using my local music library and using Tidal, also using a variety of controllers, I am having issues with no signal in the CUE feed and sometimes no signal to the channel out at all. If I turn off Crossfader Effects the problem is gone.
