I understand what you’re saying, but I don’t just want the choice that the transition only gives a limited number of bars on it. (2 - 4 - 8 -16 - 32). The automix feature does provide more options (all bars up to 32). And the transition mastering continues over the automix feature, even when the CFX function is turned off. It makes mixing much more difficult for me and the extra CFX feature is unnecessary for me. It worked better for this position. If it cannot be solved, I have to switch to another package to be able to mix properly
Hello! I want fully manual transitions. In particular, I’d like a track to end if I don’t intervene. Perhaps this is not something anyone ever wants?
If I play a song in Deck 1, then I cannot prevent djay from playing the next song in Deck 2. The only way I have found to stop this is to have no song in Deck 2. That does not seem normal to me, but maybe it is. I’d rather be in charge of my own transitions than have a mandatory automatic transition. Even if I stop Deck 2, it resumes on its own. I’m a novice, so apart from tenacious searching with google, the user manual, and these forums, I don’t have much expertise.
Settings: Crossfader FX = Off. Mode = Pro or Classic. Automix Off (“Off” meaning: Start Automix not pressed and Select Playlist or Add Songs not used). Start Playback Off. In Settings. → General everything is off except: Reset EQ…, Maintain Sync…, and Invert slider. Start Time = 0, Stop Time = 0. Autoplay when moving crossfader = off. Sync Mode = Sync + Tempo Blend.
iPhone 14 Pro. iOS 17.2.1. djay Pro 5.0.3.
Thank you for letting me know if I can turn off the automatic transitions.
djay Pro 5.0.4 was just released. We made some adjustments to the CFX and added a new simple Fade Transition with no EQing or FX. Please test and confirm that this has addressed your issues. Thanks!
Hello @Slak_Jaw
I’m about to run out of steam. Despite the 5.0.4 update, the simple cross-fader doesn’t work. I have no idea what you are testing - but it still doesn’t work.
As soon as I activate the cross-fader with the file buttons (right or left), the cross-fader FX switches on directly.
You can’t be serious any more ;-(
DJ Siggi
Looks good! The Manual and Automatic crossfader transitions are behaving as expected. I tested the basic configs I use; it’s been a very good experience so far.
Crossfader Configurations:
Crossfader FX OFF
Crossfader FX ON
Automix ON with Crossfader FX OFF
Automix ON with Crossfader FX ON
– Crossfader FX OFF –
Manual crossfades uses standard Crossfader Curve.
AutomaticTransitions (Left, Right, Inactive Transitions) use standard Crossfader Curve.
(Crossfader Curve Setting)
– Crossfader FX ON –
Manual crossfades uses Crossfader FX.
AutomaticTransitions (Left, Right, Inactive Transitions) use Crossfader FX.
– Automix ON with Crossfader FX OFF –
AutomaticTransitions (Left, Right, Inactive Transitions) use Automix settings.
(Automix Settings)
– Automix ON with Crossfader FX ON –
Manual crossfade uses Crossfader FX
AutomaticTransitions (Left, Right, Inactive) uses Automix settings.
(this configuration is the best of all worlds … in the Crossfader Multiverse)
Hi BlackJack, You asked about the stems working with Tidal: Yes, in the older version (4.1.8) you can still use stems with Tidal. I need this for my gigs, so won’t update but I’ll miss all the 5.0 fun
