- Device model (e.g. 2020 iPad Air 4th Gen): iPad Pro 12.9 5th Edition
- Version of operating system (e.g. macOS 14.4.1): 17.6.1
- Version of djay (e.g. 5.1.2): 5.2.3
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): pioneer Rev 5
Summary of the issue:
When cue point set at end of loop, when press cue pad it doesn’t exit loop and start from that cue, even though deactivate loop when jumping outside of loop is on.
How to reproduce the issue:
Set any loop, and a cue point at end of loop, active loop then press cue. Most times it will restart loop not go from that cue point. When pressing cue at loop end it doesn’t deactivate loop as should do. Cue points set further on does deactivate loop. Perhaps because it’s a cue point set at the end of loop that’s the issue. Still it should deactivate the loop all the same. I did a gig yesterday and pressed cue but it stayed just restarted the loop.
