DDJ-FLX10 now compatible with djay for Mac/Windows
This reads like good news. However, couldn’t find integration improvements like jog wheel screens working now or anything else not properly integrated until today like the pad mode. Anyways, excuses like “Pioneer is blocking access to hardware functionality” may not be valid anymore from now on …
Well this is exciting. Only for Mac and windows? Could you check the integration and let me know your thoughts.
I checked with IOS on my iPad but couldn’t find any improvements in terms of software/ hardware integration. I am not using djaypro on a laptop so I have no information regarding Windows/Mac
Any chance for iOS version support Jog display ?
Would be very much appreciated but currently it isn’t supported with IOS
Oh my, been waiting for this loooong long time.
Getting back to my flx next monday, im waiting for testing this so much :oncoming_fist::fire::man_dancing:t3:
@Slak_Jaw could you ask the engineers and ask now officially supported is there any reason why the flx 10 iOS isn’t supported on screen. Could we at least get the needle marker to be shown like the Rev 5.
Hello everyone! Yes, with the latest 5.4 djay update, jog wheel screen support is now available for macOS and Windows devices only. At the moment, I don’t have any news to share about iOS.
  • Official support for the Pioneer DJ DDJ-FLX10 controller with full on-jog screen integration, developed in collaboration with AlphaTheta (macOS, Windows)
This is amazing thank you for this amazing update you guys smash it out of the park always. One thing I have noticed since this update is the stems button now mute whereas before they soloed that part of the track. This is the same as the record box way so I get it but is there anyway to change it in the settings?
Cheers John
Hi @R99JDF, you’re welcome. Thanks for the positive feedback. There is no setting to change how the Neural Mix buttons work, however, you could easily modify to (built-in) MIDI mapping to change them from NM Mute to NM Solo. For more info on MIDI Mapping on macOS, please see below:
https://help.algoriddim.com/hc/en-us/articles/360014911871-How-do-I-MIDI-map-a-controller-on-djay-Pro-for-Mac
Perfect all sorted. Your a legend as usual, thanks so much!
Excellent! Thanks @R99JDF
And why not for IOS as well?
Hello again everyone. I spoke with engineering, and unfortunately jog wheel screens cannot be supported on iOS devices because this implementation requires HID which is not supported on iOS.
Hi, DDJFLX10 user here, excited to try DJ Pro as a long time RB user I Updated my firmware to 1.14 from the Pioneer site, verified this upgraded correctly with FLX10 settings utility, downloaded latest DJ Pro from MS app store for windows 11 and installed.
Started DJ Pro, it tells me there is a newer firmware available and to update the FLX10 the program doesn’t work.
Re loaded the 1.14 firmware to be sure, exactly the same???
The firmware update has completed fine - I’ve just been using Recordbox for 2 hours with no issue.
Power cycled the unit and the PC a couple of times each also.
Hi @DaMacfunkin, welcome to the Community! So, you updated the firmware twice (once via Pioneer and once via djay) and everything is working with djay? Or is there an issue? Please clarify if you are having an issue or not. Thanks!
Hi, The program does not work with the FLX10, every time I start the latest version app 5.4, it tells me to upgrade the firmware, you can clearly see I have the latest firmware 1.14. from my screen shots.
Program not working with FLX10 Windows 11.
As stated I rebooted machines a few times, still the same.
Tell me what other information you need.
If it can’t work I need to cancel my trial before I get charged for a year.
Thank you.
Thanks for the clarification @DaMacfunkin. Please uninstall djay, remove the djay download file from your laptop, reboot your laptop, download the latest version from the official Microsoft Store then install again.
Uninstalled DJ Pro app.
Deleted Downloaded exe file.
Restarted Computer
Visited Algorriddim site and clicked on Download, saved exe file (tried the entire process twice, once installing directly from the MicrosoftApp Store and once Downloading the exe).
Installed
Turned on Controller
Started DJ pro and restored subscription
Your FLX10 Firmware is Outdated, please update firmware.
Still doesn’t work.
Installation error. Reason I hate windows.
If something had a faulty installation, even merely uninstalling it returns a fault.
Reason i left windows 4 good
