Do you have auto gain switched on? If so this will affect the way gains operate.
Do the jog wheel displays show any information with the above midi mapping file?
Unfortunately not. You can only display your logo or the standard Pioneer or RecordBox. And that only on the MacBook. On the iPad, the display is not possible at all.
DDJ-FLX10-V8.0.djayMidiMapping (262.3 KB)
Thankyou for the effort,appreciated
Thnak you @Olivier_Frappier for all the hard work!
Is there any chance of a Windows version?
Maybe I didnāt find this one?
Thanks !
Can you get audio out from main xlr output? And does headphone cue buttons work with iPad Pro M1?
Hey Oliver
Thanks for the mapping. I just purchased the FLX-10. I have installed your mapping, Is there something going on with the samples, I cannot que my samples. im I missing something?
Try āsampler volā knob on you FLX10
at minimum ?
because sampler volume on FLX10 is mapped
tell me
Regards,
Olivier
When I hit the CUE button for the sampler itās not working. Please advise.
Thanks again
the cue button is used in my FLX10 mapping to show or hide sampler GUI, not mapped for cue
and SHIFT+ SMPLER CUE : show the loop sampler GUI
i find itās more pratical
Is there a overwiew, which button is for which function? Special all the shift commands?
or a video perhaps, i will see
or perhaps an official mapping ?
but we need a master FX section in DJAY pro like Rekordbox and VirtualDJ, and new CFX color FX missing in DJAY pro, and HID, HID like CDJ3000 with DJAY
You have done the gods work with supplying the mapping for the FLX10 thank you ![]()
@staff @admins is there any updates coming regarding the compatibility for FLX10?
Thank you
Hold up. This works on iPad??? including audio? The FLX-10 is Class Compliant?
If so, I may use your mapping and get a FLX10. I have been waiting forever for a robust 4 channel controller for iPad, with great jogsā¦ie DDJ-1000, Rane 4, Performer, FLX10, but I did not think the audio worked on any on iPad.
Yes, itās class compliant (Flx10) work with usb ipad
Agree. Purchased a Mixon 8Pro but build quality and feel couldnāt compare to even the low end Pioneer units. Returned this. Currently use a XDJ-XZ (which as the best āfeelā) but sadly this doesnāt work very well with Djay Pro. Still searching for a solutionā¦
Thank you for this Olivier
Soā¦ā¦ It seems that the flx 10 It officially supported!!! I think it may be time for me to buy one. I had the mix on eight and itās a bit shit considering ā¬1000. Thankfully, I was able to send it back!
