You’re welcome. Good luck with your testing.
The update with Flx4 support was released about a week ago. And even before that, there were several updates in the last few months. You should try to find out why you did not see these updates.
Has anyone managed to connect a lightning device (iphone or iPad) directly to the FLX4? I have a genuine USB-C to Lightning cable and nothing, a genuine USB-A - Lightning cable with an A-C adaptor and nothing.
I can only get the FLX4 to connect with a USB3 camera connector with lightning cable to power it.
Yes the FLX4 works direct to a lightning iPhone/iPad (no need for Apple USB3 adapter).
Check that your power supply supports 3A / 5 volts. Many power supplies are rated for less (1A, 1.5A etc.).
Thanks but I’ve tried with high power chargers and still nothing.
Have you actually got it working like this?
Yes it’s working fine for my lightning iPad and iPhone.
You might also need to troubleshoot your USB-C cables to see if they can handle the higher power requirements.
Here’s an older post listing some things to look for and what worked for me.
Thanks, I thought my 6.5v - 3A USB A charger with HPD cable was enough. Clearly not.
Finally got it working with a 20w (5v / 3A) USB-C charger, USB C-C cable supplied with FLX4 and Apple lightning - USB-C cable.
Thanks again
I have a 2022 M2 chip MacBook Air (Sonoma 14.5) that I am planning to DJ with.
I’ve already installed djayPro (ver5.4) and looking into purchasing the FLX4.
Anyone who recently purchased the FLX4 that could tell me if it’s now fully supported on djay Pro?
The FLX4 is officially supported in djay Pro on all platforms.
Hi @nwkt, welcome to the Community! Please use search before creating new topics. I have merged your new topic with this existing one. Yes, this hardware is fully supported on macOS:
With the Flx4, there have always been the fewest problems with compatibility with Djay Pro, at least in my experience.
Bonjour @Slak_Jaw ,
J’utilise Djay sur un Flx4, le plus souvent sur Android, tous va bien a part le bouton Smart fader qui fait le lien que pour désactiver la liaison Crossfader fx, pour l’activer il faut le refaire dans l’application.
Est-ce normal ou y a t il une solution?
Merci d’avance.
Hi again @Sebastien_Soyeux, please translate your posts into English. Thank you.
