Im noticing more and more people having this issue, the odd thing is that i experienced this with the original djay even before ios7. Really hoping for a fix FAST!
New update available this morning, lets cross our fingers!
Hey just curious, what kind of cables are you using to connect the idj pro to your speakers? I updated this morning and played for maybe 45 minutes and had no problems. I am starting to wonder however if maybe there is something with the type of cables i was using. When i was having issues more often, it was when i was using xlr to 1/4" mic cables. I recently switched back to xlrf to xlrm cables and havent had problems, sound is better too. Prob a fluke and im sure it will bug out on me tomorrow, but just a thought! I feel for you though man, really sucks.
Should be automatic. Once you connect the 30 pin connector it should recognize your idj pro right away. Sometimes mine acts funny if the screen lock is on so try turning that off. Should be a switch next to the volume button
I am having an issue (since IOS 7) with cueing. Sometimes my headphones go into “split mode” where one side is the master and the other side is the cue. I don’t like the split option therefore I don’t set it that way and sometimes while cueing the next track, the system automatically goes into split mode. I have 3 gigs per week and I cannot afford to reset the app while the club is pumping…please help!!!
Just my headphones, and usually when im searching for music to cue, it will jump into “split mode”. Its very frustrating!
I have the same problems, this needs fixing fast.
I have sent my idjpro away for repair, seems it’s the software that’s the problem not the hardware then. I can’t take on anymore work until this is fixed, and the lack of support from Djay is abysmal.
Agree totally they just broke a brilliant product, they must fix or refund.
Hi guys, it’s time to up the pressure on Algoriddim as they are not addressing the issues we are having. I suggest you put all these issues on there Facebook page where everyone can see what’s going on… I’ll see you on there…
Can someone please tell me the steps to connect my I pad 3 to my idj pro? I just got the I dj pro but whenever I connect my iPad to it algoriddim djay app doesn’t work on it. I’m using the version 1.4.1 or djay app. I turned all the MIDI settings on n still not working!
Thanks for helping n letting me know it has to work automatically. Apparently I needed to upgrade my djay app from 1.4.1 to version 1.6. Now it works fine. Happy new year cheers
so i just upgraded to djay2 last night and it crashed anytime i tried to load the song list. i resynched my playlist , turned everything on and off and id lose it again. anyone have any ideas? i had to manually dj a party last night w just my iTunes! it was embarrassing to be there w all this equipment not working. i use idjpro btw. need help have many gigs coming up!!!
I am having the same issue with Djay 2 using the Reloop Mixtour controller on an ipad (2018) (ios 11.3.1), 5 years on from the original post! The master output randomly goes into split mode with the mix on the left and cue on the right (the same on headphones too), usually after 45 minutes to an hour of mixing and when accessing the library. Obviously I do not want this happening during an actual gig. Is there a fix or a work around? Searching other places it seems that this issue has been occurring since at least 2013. Is Djay Pro immune to this bug?
