I purchased djay 2 and wanted to connect it with spotify (I have a regular account).
Whenever I want to login to spotify (in djay 2) I get an error message: “Login failed! Cannot connect to spotify!”
It seems like it’s only on the Facebook Spotify sign in can’t even signup to Spotify throughly the Facebook login. The app hasn’t been updated since May.
This didn’t work for me. Generated the password through Facebook and tried using both my Facebook email and the Spotify number (device username in my Spotify account details) as usernames along with the generated password and it still says incorrect username or password
Hi Patrick
I had the same problem after changing from iphone 4 to 5 with icloud…
just reinstall the app and it connects o spotify again!
hope that works for you aswell…
Greetings Anders
we are very sorry that you had to to go through this work around in order fix the problem.
At the moment we are investigating the problem and are trying our best to fix the Spotify Facebook issue as fast as possible.
Patrick, could you tell us under which djay version, device and operating system the problem occurred?
Enter your current Facebook password and click Submit
Enter Spotify, and Facebook will automatically generate a password for you. You can use this with your Facebook email address to log in to Spotify on any device
We got feedback of other users that this procedure fixed the problem, please contact us right away if this is not helping.
Can you log in to Facebook in Safari and connect your iPhone to your local Wifi?
Now try to log in to your Spotify account again and please contact us if it did not work.
thank you for your feedback.
We are trying to provide a fix as fast as possible
Please make sure to be connected to your local Wifi in the whole procedure.
