Hi team,
I did a quick test regardant instant double behaviour and it is working fine now ! Great job!!!
I will test it more deeply in the next days.
Tony.
I still haven’t actively tested the update. But it looks like some of the problems have been solved. From what I noticed - there is a problem with the indicator for switching performance pads when exiting sleep mode or rotating the screen. the device selector still doesn’t work and the cue mixer buttons don’t sync with the interface if the app for some reason activates them on its own, for example based on the crossfader position.
The update is good but what happen to match, still will not match your own library. Well let me correct that, you’ll get about 4 or 5 matches then it stop? I love match when im doing a set cause sometimes it will pull up songs you haven’t thought about
Thanks, I have made that mistake before in the past and got caught out with a glitch that was thankfully resolved…
The night was great and went without a hitch, booked for 4 hrs and they asked me to play an extra 2hrs…
At the moment, the Pioneer DJ DDJ-REV7 jog wheel screens aren’t supported on djay. We appreciate the feedback, and I’ll pass it internally to our team for future developments. Thanks again for reaching out!
I haven’t been able to reproduce these not working. You should be able to access the sort and filter options without scrolling to the top of the list with a slight downward finger drag on the playlist. Please reach out to our Support Team via email if you need individual support with this. Thanks!
