Djay Pro 2.2.8 to 3
Hi, I am currently using Djay Pro 2.2.8 on a High Sierra MacBook Pro mid 2012,
The streaming is from Tidal Premiun and generally works well although there are some problems with the grid.
I wanted to know if these problems are solved in version 3 as I would have to upgrade my MacBook Pro system and this is quite cumbersome.
Are there any improvements in relation to Tidal?
Kind regards
Diego
2 posts were merged into an existing topic: Beat Grid problems with Djay Pro 2 & 3 + TIDAL Audio Resolution Query
