I’ve just installed the DJay Pro (via the App Store) on a new MacBook Pro (running OSX 10.10.1.
iTunes plays all my tracks without any problems via a drive running from my Apple Extreme but DJay Pro just throws up the following error: Could not load track: The operation couldn’t be completed. (OSStatus error -54.)
Any ideas? It’s a bit of a shame that I can’t use a brand new piece of software!
just installed jday pro this week and found this thread after searching for the error. I am using an external HDD for all my iTunes music. it was working fine for several days using both spotify and itunes, then tonight itunes starting throwing the error. tried to eject and plug HDD back in and quit and restart the app. not working still…
I’m having the same problem, but with a NAS (Synology DS1813+) attached via gigabit ethernet, not wi-fi. This is an issue only with djay Pro; djay 4.2.3 continues to load everything as expected.
The specific problem being discussed here (failure to load songs on network-attached disk that would otherwise properly play in iTunes and the earlier, non-pro version of Djay) was a bug that has been fixed along with myriad other bugs in one of the subsequent point releases.
I’ve tried a permissions repair. I’ve now discovered that SOME tracks play - but the vast majority give the error message. I’ve tried playing the same tracks through iTunes and they are fine there, so there is something screwy with DJay.
Hi - I’m the guy that started this thread. Since the update, DJ Pro doesn’t play ANY iTunes track - I just get the same ‘Could Not Load Track’ error.
I’m very disappointed - it wasn’t a cheap app, and I’ve not yet been able to use it.
My only thought is that it is due to having my music stored on my network, and my iTunes Library files are local, something is screwed up (although this works fine for iTunes itself).
I’ve tried fixing permissions, resetting the PRAM etc - but this app is proving useless.
I’ve been restarting and trying again and again… Now the only songs it WONT play are the songs in my “recent purchases” which ate about 200 songs… Also the tempo doubling/halving doesnt work, the number changes but the tempo remains the same not looking good for the future of this product
I am having similar trouble as described above. Djay Pro is not loading any of my iTunes tracks regardless of location of the library files. My iTunes library is split among multiple drives (internal and external), but Djay cannot load/play any of these files.
Permissions for all iTunes-related directories and files are set to 755 and 644 respectively.
