Hi - I’m using DJay Pro for Mac and have a Beatport link account. When I open Djay on the library tab on the left it has soundcloud, Tidal and Apple Music but no logo for logging into Beatport Link.
Can you post a screenshot? Are you on djay Pro AI?
Are you using one of the new M1 silicon powered Mac’s? As I believe that Beatport integration only works on Intel based Mac’s for the time being.
Hi Stu - yes I am so that explains it. Thanks
I have no option to login to Beatport when using djay Pro AI on MacBook Pro with M1, Big Sur 11.1.
The option for soundcloud & tidal are there only.
I can login using the same Mac using djay Pro 2.
Hi @GregStienlet,
I’ve moved your topic thread here as the question/solution is the same. At the moment, Beatport and Beatsource LINK are currently only available in djay Pro AI on Intel-based Macs. Sorry for any inconvenience. Our development team is currently looking into how this might be expanded in the future and we’ll keep you updated.
FIX
Brilliant - fixes the problem so easily. Nice hack. Thanks for the tip.
