Hello,
I just bought the full version of Djay pro,
I use it mixing playlist from Itunes and Spotyfy.
So i set up a playlist in the Queue and let automix go through the list. While making small adjustments to the list or manual transitions half way some songs but I am not using any transition effects or any kind of sound enhancement.
After aprox 2 hours of playing music the program crashes half way a song. It has happen twice already so I am not using the program, the first time i was updating the playlist so i thought it was my fault or a glitch. But the second time the music was just playing half way a song and it stooped and crashed out of the blue.
This is a serious problem because I am not using the program for recreational proposes. And it has gotten me into a real awkward spot.
This are my computer Specs
Lenovo pc Y50-70
Intel Core I7-4720HQ @2.60ghz
8 Gb Ram
Nvidia Gtx 960
And I am using an external Usb Analog Mixer for the Audio output
Henyx Q502USB (Behringer)
With the same hardware I have never experience a crash neither in Spotyfy or Itunes.
I hope you can bring a solution soon or in case you cant I will ask you to refund the money, because this is unacceptable, It is a real shame/ I was really looking foward to this windows version of Djay Pro, but such a fatal crash while playing makes it useless.
