I have been having a very frequent issue with Djay Pro, as it has troubles recognizing my dj board.For it to recognize, I have to continuously restart my computer until it works again… The issue has been extremely annoying, and has discouraged me from using the app again, have anyone else experienced these issue before?
Hi again @Jake_Waggoner, I’m following up on my post from 7 days ago. If you are still having issues, can you please respond to my post above? If I don’t hear back in a few days, I will consider this solved and close the topic. Thanks!
I have a Hercules DJ Control MIX Audio Mixer (38968631/p?utm_source=google_products&utm_medium=merchant&id_producte=16314850&country=au&gad_source=1&gclid=Cj0KCQjwhtWvBhD9ARIsAOP0GogKRCQ6tblu6ARfGHu-aP6tLPksJ_8Unen-nVJP0yuP4T3dDDb7be8aAozpEALw_wcB) and it used to work with DJ AI pro on my Mac PRo with Sonoma 14.4 until recently. I connect it and my DJ AI pro app does not recognise the controller but you can see the controller is turning on.
the controller does work on bluetooth with my iphone but not with the my mac. Are you able to assist or guide me on how to fix?
Can you please share exactly how you are connecting the DJControl Mix to your Mac? For example: wired USB connection, wireless Bluetooth connection. Photos of all connected cables and adapters would be helpful.
Do you know what has changed in your setup between when it was working and when it stopped working? For example: macOS update, djay update, different cables or adapters.
Please share a screenshot of your djay Settings>Audio Devices
Please share a screenshot of your djay Settings>MIDI Devices
Hi @Justin_Edge, thanks for the additional details.
I suspect the issue is with that USB adapter and cable you are using.
I recommend you use a high quality USB cable with the right connections on both ends so you don’t need an adapter.
I’ve had many cheap adapters and cables fail over the years.
Please note that not all USB cables work the same. Some only work for charging and cannot transmit data. Some have limits on the charging power and some transmit data at different rates.
Hey I used Hercules DJControl Mix too and I have been using it for the last 9 months at least.
First of all, i believe this is a Bluetooth controller, rather than a ‘cable’ controller.
95% of the time i use it with my Ipad Pro Gen 5 12.9", prior to this was Ipad Pro 11" Gen 2/3 i think and prior to this was Ipad Air 11" something.
The remaining 5% i had to use 3 times with my Macbook Pro M1.
I have never tried to use it with a cable but rather through the Bluetooth to MacBook Pro.
Here’s roughly how i did it.
Only for macOS Sonoma 14.4:
Please check https://discussions.apple.com/thread/255518397?answerId=260260788022#260260788022
in order to see if the cable/USB/hub … is considered as USB asking permission under system settings → privacy and security → allow accessories to connect. This is new feature in macOS Sonoma 14.4. Waiting apple to fix it
