DJAY2 not working properly with IOS 7 and Pioneer controller
Ok then…Thanks Samuel and Warren…
Allright…really thanks again…
It is lrobably the same as the one up there (fron Warren’s comment; copy paste to below)
http://pioneerdj.com/support/product…
And below is the link you mentioned…Anyways I will find out one way or other as long as I know that firmware update solves the problem on wego 2.
http://www.pioneer.eu/eur/support/sof…
Pop noise with Djay 2 and DDJ Wego.
Hi, I have a problem with the Djay 2 when i connect with Wego DDJ and play songs i hear a continuous pop noise on master channels and I’m sure is not the wego, I use it with virtual dj and serato and I have no problem.
Any idea why this happening
what about with a iDjPro???
Ipad 2 with pioneer wego 2.
When I connect my ipad 2 to the wego 2 I get a clicking noise and the sound is distorted. Can anyone offer any advice please?
Ipad 2 7.0.4
wego 2 1.01
Pioneer WeCAI
Thank you
hard click-sound with ipad mini retina/ipad air/iphone5s (2013 version) with wego2.
Hi, if i got my ipad connected to the wego2 and it plays and the headphones are switched on, i have a hard high-kick/snare sound out the output - if i connect the wego2 to the mac, this sound is not there - at moment i cant use my ipad and that make me very sad - what is the problem? Wego2 need to rechecked? Or is the app not able to work with the 64bit processor? (Iphone5s/ipad air/ipad mini retina)
I have a DDJ Wego1 with Djay 2, I have my ipad air running IOS7, I have purchased the cables and nothing works, really dissapointed.
I have followed the advice in this thread and updated the wego to firmware version 9.09 and have update Djay 2 to the latest version in app store, still nothing.
I have restarted the ipad and followed the connection instructions, why isn’t this working??
This firmware does not work… I have a WEGo2 with a Mini Ipad with iOS7 and still hearing a ticking sound … very annoying… contacted Pioneer and they are aware of this issue but are blaming DJAY software and not compatible.
Yesterday I bought a DDJ WeGo2. Do I have to install something to use the iPad app? Because I have an iPad 4 and I connected the Pioneer DDJ-WeGo2 to the iPad and then opened the djay 2 app and it happens nothing. Why doesn’t recognise the controller? Please, help!
How can I stop the ticking noise in Djay 2 from my Wego2? Help please!!
Hello Sinan, after updating the WeGo2 firmware it works excellent. I recommend the WeGo2. It’s perfect now it is solved
I don’t know. It worked for me
Actualize firmware of the wego
You’re welcome. Do yo want me to give you the download link??
Anyway, this is the link. Make sure to download the manual instructions of updating: http://www.pioneer.eu/eur/support/sof…
Cracking Sound In Headphones.
I’m using djay 2 on an IPod Touch 5th generation, with dj-wego2, and when I plug my headphones into the dj-wego2, the music goes in and out with a cracking sound. And when I plug the headphones into iPod, the cracking/clicking sound goes away, but lots of the functions fail, like the crossfader and tempo. Any ideas? Thanks!
Hi :slight_smile: I have a iPad2 with iOS 6…I would like to buy The Pioneer WeGo
and I am wondering if it works because Apple and Pioneer say about iPad 4th generation or iPad mini required
with adapter and cable I need to buy?
and if it works,what you advice me to buy?the WeGo or the WeGo2???
thank u for the answer :slight_smile:
I noticed you have same configuration as me
Joël Suburbass TwentyThree 1 day ago
Hi my djay in not working properly on my ipod can someone help thanks
