Almeno dateci una spiegazione di come mai non funziona! Come si fa a tornare ad ios 6. ecc se si puo tornare?
Te lo abbiamo spiegato la soluzione quale e?
Help urgent.
So I was playing at a gig the other night with my ddj ergo connected and installed and the night before I downloaded ios 7 whenever I open djay 2 and play music all I get is an annoying thud coming out of the speakers, it isn’t my speakers because when I go onto my music library and play music through my speakers everything is fine. I’ve tried closing it turning it off everything possible. It is defiantly a issue with djay 2, and I would love if u guys had time to reply back
@algoriddim I just talked to Pioneer support, they told me it’s definitely a problem between IOS7 and your app, please fix it!!!
PIONEER WEBSITE:
“To customers who use DDJ-WeGO:
Pioneer has been researching compatibility with iOS7 when it is used with DDJ-WeGO.
We have found an issue that a noise is heard in the audio output when iPad with iOS7 is used with DDJ-WeGO.
iPad users are advised not to update to iOS7 until the compatibility is verified.
Please note that once you updated to iOS7, downgrading to iOS6 will not be supported by Apple.”
Perfect!!
until now everything fine after updating the firmware
I dont know. There are other programs on the ipad that worked with the pioneer wego. Like mixvibes. All same thing. Loud.clicking noises. Tells me that its the controller that has problem .
Yea its my fault for updating. But io7 beta has been out for a minute.
my foot goes in mouth, lol! works now
has this issue been resolved? i had the same thing happen
Idj pro will be updated I take it or is this bit of kit useless now
Wecai ipad ios7.
Just bought the cable, got home and… It’s not working!!! Heavy scratches are constantly in background :(((((((
After 40€ for the cable and 29€ for the apple cam cable and the money for the software… I expected at least it worked!
Any suggestions?
Spin 2 set with idjay 2 and iPhone 5 is having major issues cue is not setting and loops are going crazy someone help please it’s driving me mad
spin 2 also issues beat matching even using sync its clashing this is annoying the hell out of me
After the solution of updating my wego to 9.09 firmware the sound of ticking and distortion has disappeared so thumbs up for that but in reply to this topic I have also been having random disconnection between the ipad and wego probably around every 10/15minutes. But this only lasts for about 20/30 seconds and reconnects automatically. Just wondered if anyone else has this experience just so I know it’s not my camera adapter kit. Can’t really see it being my wecai cable because i only bought it 4 days ago and it’s the official pioneer one. Thanks in advance.
Dale
Forgot to mention that my ipad has been updated to IOS 7.0.2 and DJAY is updated to date. Did these disconnections happen to anyone on IOS6? Thanks again.
Dale
I have the same problem , please one solución
Hi. I have ddj wego and it doesn ́t work with my Ipad. I have DJC-WECAI, i updated IOS7 and firmware 9.09 IOS7. The controller turn on but it doesn ́t work. When i press Browse button Itunes doesn ́t open to choose the song.
The message " DDJ-WEGO NOT SUPPORTED. DDJ-WEGO REQUIRES TOO MUCH POWER". Which adapter power could i use? My DDJ-WEGO worked perfectlly with my computer Windows7. Help me please.
Dear Algoridm Support Team,
Is Pioneer DDJ 1 (originally designed for Traktor software) compatible with Djay 2 on iPad (4th Generation) ?
I like Djay 2 more than Traktor and I have been using it on my iPad…Djay 2 just seems more user friendly to me. If it works with Pioneer DDJ 1, it would be great…
Note: I have iOS 6.1 on my iPad and I am afraid of upgrading to iOS7 due to all these problems described on this forum. By the way, I am not dying for 7 but if it is OK to use with Djay 2 with no problem, why not…
I am looking forward to your reply…
Sinan
Hello Warren,
Can you please clearly confirm that there is no problem to connect ipad 4 (iOS7) with WEGO 2 CONTROLLER after firmware update of WEGO 2…
You always have the same answer (firmware update) but people still send comments (tehre is a stilll problem).
I am planning to buy WEGO2 and I want to make sure it works fine with djay 2, which I am used to.
