Do the Kontrol X1 and Xone:K2 work on iOS?
Before I go out and buy a powered Xone:K2 and a powered USB hub for my X1s, do they work on iOS? (I want a really tight/compact DJ setup with no jogwheels. I like buttons/knobs/faders.)
I understand I would need to create a mapping.
The reason I ask is, I tried plugging my Kontrol Z1 into my iPad/iPhone, and despite there being a MIDI mode in the Z1, it doesn’t work on iOS.
Thanks.
Hi @kokernutz,
We’ve tested the Xone:K1, it works. The Xone:K2 is the same but with a class compliant audio interface so it should work fine on iOS.
The Kontrol X1 isn’t class compliant. The Z1 isn’t either. These devices will not work on djay for iOS.
Great. Thank you so much for the prompt reply.
