Thanks for the input @EwoutdeBoer
Hey @Armigo, engineering is asking for your djayMediaLibrary database file. Can you please upload it to your Google Drive/Dropbox, **enable sharing permissions**, then share a link to here or send it to me in a DM? On macOS it can be found in **~/Music>djay**. Thanks!
I have cleaned them completely, as you aware the time I dedicated to learning them.
Just now b4 typing this, l double-checked via a CSV export first, no single ghost file (no duplicate url found in excel).
Does it matter? Should I still send? If yes, give me tomorrow as the file is ~300MB - I will upload when the network is steady.
Thanks to you, I have been avoiding all known triggers since beginning of this topic.
I could trigger a new ghosting glitch, but right now am not very comfortable as the ghosting, unpredictable as it is, goes beyond the bounds of my experimental trigger and takes quite some hours of work to get back to zero ghost.
Hi @Armigo, yes it would be great if you could still share your djayMediaLibrary database when you get a chance. No rush though.
Thanks @Armigo
Did this get resolved? I’m hoping for an underlying fix to the app to prevent this from happening to others in the future.
This is still being investigated by our engineering team.
