EQ resets when using crossfader fx and tempo blend
Using latest version of DJAY and wondering is there anyway when using crossfader fx and tempo blend that your EQ presets can go back to what they were previously set at? Right now every time you cross over you have to set your EQ’s manually again.
This is a well known issue as it also affects when using Neural Mix on the eq dials and then toggling Neural EQ…
Hopefully this will be fixed in upcoming updates…
Hi @ChrisM, sorry for the late response. Currently this is a limitation with how the Crossfader FX system works. I have another user with a similar use case to yours so I understand the issue. I have already shared all the details with the engineering team to see what they think. I’ll report back when I have news. Thanks!
This has been addressed and in a upcoming djay release (likely 5.2), switching between EQs and Neural Mix EQs will no longer reset the EQs.
Am really waiting on this,
