Yes, even though songs around 130 usually analyze well, sometimes they don’t. I’m not sure why? I’m sure the algorithm is complicated and just gets confused from time to time… That’s why humans make better DJs?
The fix is easy enough ONCE you know which song it is. Just tap on the bpm within djay and you’ll see some options, one of which is “tap”…
… The trouble I have with the BPM being wrong with the analysis, is that you have to stumble upon the songs that are wrong.
… I’ve already analyzed all the BPMs on my songs and set up my playlists the way I like… but djay sorts by their own BPM (or “ABC” by song title)… Not the end of the world, but I wish I could just use my iTunes’s BPM to sort… problem solved for me.
(… there are a few desktop software options that you can use to analyze the key and BPM of your iTunes library… BeauTunes is one… it too is not perfect. I then use a program on my mac called “Cadence BPM Tapper” to manually measure songs that are wrong. This little program is nifty in that you play songs right from your iTunes then tap and presto your BPM is updated… This can be time consuming, but at least your listening to music you like? keep in mind that the iTunes BPM field is only an integer, so you just need to be close. It’s more of a field for sorting than what you can use to auto-beat-match)
…Of course, the tap in djay is only as good as your tapping ability… but it get’s close enough even if your not perfect (like me)…
…For these manually tapped songs you will probably need to be a little more active on the push and pull ("+" and “-” buttons) to keep this track beat-matched with your other deck. Or worse yet… you might have to manually adjust the slider!
… That said… the slider can be hard to adjust exactly as you want. A Technics turntable has a very accurate pitch slider that you can ‘pinch’ to fine tune, or even ‘cross-fader-crab’ to push and pull if your fingers are too dirty to touch the vinyl…
… The djay slider is hard to push and then pull back to where you want quickly… it also seems to ‘bump’ slightly as you lift your finger… just take a deep breath and try to stay away from extra caffeine when operating the pitch slider…
again… these are just details for me that would make the app perfect… overall this app is very very good and very very fun to use… I’ve spent a lot of hours on it lately, more so than my real turn tables or Tracktor! what’s the world coming to?
