- Device model : iPad Pro 6th Gen
- Version of operating system : iPadOS 18.6
- Version of djay 5.4.:
- Hardware/controllers used : Pioneer DDJ-FLX10 firmware updated to v114
Before the update the FLX10 was perfectly MIDI mapped, after update all mappings are gone.
It shows an empty MIDI template.
Could you please add the correct MIDI mapping file, so that it is automatically mapped again.
Hi @JohanMoritz, thanks for the details about your setup and the issue. Please close djay and follow the procedure linked below to perform a Forced Restart of your iPad: Force restart iPad - Apple Support (IE)
After rebooting, if your MIDI Mappings are still missing, can you please share a screenshot of this window? Thanks!
Hi @Slak_Jaw
I performed the force reboot but that didn’t fix the issue.
Hi @JohanMoritz, thanks for confirming and for the screenshots. I have passed this onto our engineering team to see if they can replicate it and offer any suggestions. I’ll report back as soon as I have news. Thanks!
Hi again @JohanMoritz, we have identified the issue and are working on a fix. In the meantime, I have attached a MIDI mapping for iOS that will restore most FLX10 functionality except ColorFX and BeatFX.
To install the MIDI mapping, simply “open” the mapping file once you have sent it to your iOS device via AirDrop, email or downloading from here. I hope that helps!
Pioneer DDJ-FLX10 iOS.djayMidiMapping (441.1 KB)
Thanks @Slak_Jaw for getting this going so quickly.
The workaround (midi file) works!
Thanks again
You’re welcome @JohanMoritz. Happy to help. I’ll report back here when we have a more permanent fix.
Hi again @JohanMoritz, djay 5.4.1 for iOS is now rolling out to the App Store and should be available within the next hour or so. It contains a fix for the DDJ-FLX10 not getting detected (no other changes).
Hi @Slak_Jaw ,
Thanks for the super fast fix!
Johan
You’re welcome @JohanMoritz. Happy to help!
Why is djay pro like this i dont seems to get it i updated to the new 5.4 and flx10 wont map automatically as it was on 5.3 thank God i have my laptop with me it would have been shitty set up im pissed the output working perfectly but no button was working on the flx10 with my iphone it saying i should map it manually where do i want to start from mapping each button when im in a gig
pls find something to do about it im really pissed off
I really wish i can go to the previous version tonight im really pissed off
Hi @Brown_bkp, please use search before posting in the general 5.4 Release update topic. I have moved your comment to this existing topic. We released an update to fix this issue yesterday on iOS. Please update to djay 5.4.1 to get the patch.
It was working perfectly on 5.3 with flx10 not untill now that i updated to 5.4 and everything went wrong 5.4 was a new update so it should be considered a new topic the topic you merged my comment with was 2023 2 years ago im really pissed
@Brown_bkp, my apologies, I accidentally moved it to the wrong topic then moved it here. Please update to 5.4.1 on your iOS devices as outline above or download the MIDI mapping above that I shared yesterday
Have updated to the latest version that was released today
If you are already running the 5.4.1 fix on your iPad and iPhone and it’s still not working, then you can manually download the FLX10 MIDI mapping as instructed above.
I checked my appstore i didnt see any option to update which means im fully updates
Try logging out of your AppleID, rebooting your device and logging back in. 5.4.1 was released to the App Store yesterday.
Let me try this i will be right back
