Hercules Inpulse 500 Neural Mix Mapping
Can i map neural mix to the hot cue pads on hercules inpulse 500. i am operating on a macbook air and the latest version of djay.
Hi @Djflames7374, yes, you can manually adjust the built-in MIDI Mapping to control Neural Mix. Please refer to the MIDI Mapping guide below for macOS as well as another Community Topic where I offer some specific suggestions. I hope that helps.
https://help.algoriddim.com/hc/en-us/articles/360014911871-How-do-I-MIDI-map-a-controller-on-djay-Pro-for-Mac
This works very well. In general, you can use the elements of most controllers in almost any way you like. On the Inpulse 500, for example, I have assigned the pad mode sampler with neural mix functions, but also the three buttons at the top of the controller with mute drums, harmonics and vocals, so that this is always accessible without having to switch the pad mode.
