how conserve iTunes stars rating when importing tracks into myLibrary?
In my iTunes library I have 25k+ tracks with ratings (stars) which are incorporated in many smart playlists. I cannot live without them.
When I import tracks from iTunes to myLibrary, the rating will not come along.
This is very annoying.
Please extend the import function with this field.
Hi, the rating field is visible in the playlists inside “My Library”, but the songs are not populated with the actual ratings from iTunes:
 See Screenshot attached
Running MacOS Mojave 10.14.6, DJay Pro 2.0.15, iTunes 12.9.5.5
Hi, any news on this? I have upgraded to the latest 2.0.16 still no difference.This is a major pain that really limits the value of the Day Pro Library feature.Could you consider this enhancement for the next release?
Fixed in 2.1. Thanks Guys, keep up the good work!
Thanks for pointing this out. I have added the missing rating field to our feature list for import in My Library.
