How to calibrate DVS with DJM-A9 and CDJ-3000?
I want to connect my iPad to DJM-A9 via USB cable and play rekordbox or serato DVS signal on CDJ-3000 via USB memory and enable DVS with iPad.
DJM-A9 is class compliant, so it is recognized as Audio Interface on iPad, but DVS signal did not display and could not be calibrated.
Incidentally, DJM-A9 and CDJ-3000 had connected by line or digital cable.
Please tell me how to do calibration.
iPad mini 6
iPadOS 17.6.1
djay pro 5.2.5
If you want to use Rekordbox or Serato, why are you asking on the Djay forum?
Hi @Akifumi_Konishi,
  1. You will be using the A9 in External Mixer Mode in djay so all of the mixing will be done on the hardware instead of using djay’s internal mixer.
  2. Note that djay only supports 1kHz time code signals, so make sure that’s what your CDs are using.
  3. When you want to use cues on the player you should consider using ABS mode, otherwise it can become confusing.
  4. For more about DVS setup please refer to the links below:
I’m using djay Pro.
DVS signals are files released by Rekordbox or Serato.
I have it connected like that, but I couldn’t calibrate it.
I was able to calibrate using Denon DS1 as audio interface.
https://x.com/758kenmin/status/1812832930093572448
This post states that DVS could be used with turntables, but not with CDJs.
https://x.com/758kenmin/status/1814621986087420379
The post also states that you can use DVS with CDJs by connecting PHONO through a converter equipped with a reverse RIAA filter.
Does djay Pro for iOS only accept PHONO input when using A9?
Hi @Akifumi_Konishi, DVS should work with CDJs as well. The calibration settings are found in the djay Settings>DVS.
I believe both users in the linked topic below were able to get this type of setup working. Although with different mixers than yours.
  1. Perhaps there’s an issue with how you are connecting to your iPad. Are you using a genuine Apple Camera Connection kit and is it connected to power using your original iPad charger and cable?
  2. Are you running the latest firmwares on your mixer and CDJs?
Settings>DVS selects the A9 channel.
But djay can’t receive DVS signal.
The iPad mini6 and A9 are connected via a USB-C cable only.
Of course, there is no problem if you just use the A9 as an audio interface without using DVS with this connection method.
Mixer and CDJ firmware are latest version.
Could you also verify it on the Algoriddim side?
Hi @Akifumi_Konishi, thanks for the additional information and screenshots. This is very helpful. I’ve passed this onto engineering to see if they have any suggestions. In the meantime, have you tried using a different USB-C cable? Ideally a genuine Apple cable or a reputable brand high quality cable.
I tried several USB CtoC or USB CtoB or USB AtoB + USB Hub.
None of the cables could receive a DVS signal on djay pro for iPad.
It could not calibrate when connecting the iPad and A9 directly with a USB cable.
iPad mini 6 - A9 (USB Cable)
CDJ - A9 (Digital or RCA)
It could calibrate when use Denon DS1 as an audio interface.
iPad mini 6 - Denon DS1 (USB C to B)
CDJ - Denon DS1 (RCA)
A9 - Denon DS1 (RCA)
Hi @Akifumi_Konishi, I checked with our engineering team. They were able to get this to work with iOS, but unfortunately the behaviour is inconsistent. There seems to be a bug with the A9 mixer where it reverts back to Phono when you power it off then on again. Anyway, here is the process that worked for us:
  1. Connect the A9 mixer to a Mac.
  2. Download, install and launch the DJM A9 utility settings.
  3. Set all channels to Line.
  4. Connect the mixer to iPad.
  5. Connect the CDJ via RCA cable by plugging it into the Line input of Channel 1.
  6. Launch djay, calibrate needle on Deck 1.
  7. Repeat for Deck 2.
Unfortunately, it seems you will need to repeat this entire process every time you turn the mixer off then on again as it will revert to Phono input. I hope that helps!
Thank you for checking.
In other words, I understand that if I want to enable DVS on iPad and A9, I’ll always need a Mac.
I wanted to use DVS only with my iPad, but since I needed a Mac, I found that this connection method was completely pointless.
I wish there was DJM-A9 Utility Software for iPad.
Basically yes. Unless Pioneer changes the firmware so that the A9 doesn’t always revert to Phono when turned off. In that case, you would really only need to connect to a Mac with the Utility Software once to make the adjustment.
By inserting the reverse RIAA unit between the CDJ and A9, and connecting it to the A9’s phono input, I was able to perform DVS playback using the djay app on my iPhone.
@Akifumi_Konishi Did you solve your problem yet? I made Rekordbox CD Timecode RIAA inverse ver.
You can see the detail and download in my post.
