How to set and view cue notes
I am new to Djay and I was wondering how I can best add written notes to my cue points and see them on the grid/wave form. If this is not possible, can this feature be implemented? It would be great to see the reasoning behind a certain cue point in a glance.
Also, I was wondering how and where cue points are saved and synced. Some explanation on that would be very helpful. Thanks!
  1. The “Tools” area next to the jog wheels can be used to edit cue points. The example below shows a cue point named Vocals #1.
  2. In macOS, there is also a toolbar called “Tools Bar” :roll_eyes: :thinking: :face_with_raised_eyebrow: (underneath the Play button).
notes: by default, time stamps are shown, otherwise it shows the name.
Hi @oleander, welcome to the Community! Please confirm if what Michael shared above answered your question.
As always, thanks for the help and perfect explanation @Michael_Wisniewski!
Thanks all, found it!
Is it possible to display the notes on the waveform?
And could you maybe also explain where the cues are saved? Is it like a local file that keeps track or are they somehow uploaded to the cloud?
Thanks again!
You’re welcome @oleander. It’s not currently possible to display the hot cue names on the waveform, but this has been suggested below if you’d like to go there an vote for the feature:
The hot cues are saved in the djayMediaLibrary database. You can find out more below:
https://help.algoriddim.com/hc/en-us/articles/360014912211-Where-does-djay-Pro-store-playlists-cue-points-and-other-data-on-my-Mac
Is there such a feature on the iPad version as well? I would like to have some notes for tracks. Doesn’t have to be timestamped.
Hi @Alpackan, yes you can rename your hot cues and saved loops on iOS as well.
Ah! The term “renaming cue points” made me look at the right place and your terrific screenshot. Haven’t found that panel before, have made all cue points with external hardware.
Many thanks.
/Alpackan (John)
You’re welcome @Alpackan
