I want Help with Fine-Tuning Sound Effects
Hey everyone,
I have been using djay Pro AI for a while now and I am loving the features so far. I have been struggling a bit with the sound effects. I am trying to figure out how to fine-tune the reverb and echo settings during live mixes but I am not sure if I am using them to their full potential.
Also I have checked the manual and a few YouTube tutorials but I am still not getting the exact results I am aiming for. Are there any tricks or settings that you guys use for adding the perfect amount of echo or reverb without overdoing it? Maybe some tips for syncing them with the track tempo or keeping things smooth during transitions?
I was also considering taking a java course online to improve my programming skills. Does anyone here have experience with mixing tech and music production, or is it better to focus on one thing at a time?
Also i have check this Ipad with Ddj wego 3 Sound is gone with AirPlay ( want only send video with djay pro) still want help. I appreciate any advice or insights from those with more experience!
Thank you…:slight_smile:
Hi @mitasali, here are some suggestions that might help.
  1. Make sure you are using the Manual FX section as this offers the most control of the FX parameters
  2. Adjusting the D/W dial will help you to control how dominant the FX are relative to the underlying song.
  3. You could also consider applying the FX to just the Vocals, Instruments or Drums using the FX Routing. This can really help to control the end result.
  4. Finally the Parameter Sliders can be used to further shape the sound and control the beat interval.
I hope that helps!
