Hello,
I use the ipad with the DDJ Wego3 and Djay Pro.
I want to use it with AirPlay to appleTV only the Video !
But when i put airplay “on” my
Sound on the ddj wego 3 is gone!!!
Thanks for help !
Hi eM2Yu,
thank you for your post.
Unfortunately the iPad is not able to split Video and Audio Output. As long as you want to send a Video signal the Audio is going the same way.
What is the point of purchasing “pro” level app for ipad that does not allow the Pro to use a mixer to output sound??? Will this be fixed soon?
