iCloud not syncing playlist
MAC mini
M1 16 gig memory
macos 15.6.1 (24G90)
djay pro 5.4.2
IPad OS Version 18.6.2
IPad Pro 12.9 6th generation
available storage 91.88 GB
djay Pro 5.4.2
Summary of the issue:
iCloud is not working with djay pro
iCloud functionality is working well with other items syncing from from mac to ipad. however nothing is syncing from my mac mini to my ipad . I have verified everything is setup correctly. I tried to upload a video but since im a new user i can’t.
I also verified on my ipad that im signed in using my same account, no vpn, ipad setting advanced-icloud status is active last updated 9/15/ 1:30pm
How to reproduce the issue:
Hi @DJAsync, welcome to the Community! Please note that iCloud Sync does not support playlist syncing. Track metadata generated while using djay on your Mac, iPad, or iPhone is automatically synced via iCloud. This includes cue points and loop regions per song. Other metadata like BPM analysis is currently not synced.
https://help.algoriddim.com/hc/en-us/articles/360014702832-How-do-I-enable-iCloud-syncing-on-iOS-and-macOS
Ok..Let me know sure i understand what your saying. Are you saying that my music in djay pro on the mac will not sync to djay pro on the ipad?
That is correct @DJAsync. You need to manually sync any Local Music using the Music/iTunes App on your Mac with your iPad connected. Once your local files are synced in that manner, you can also manually sync any playlists you create in the My Collection Source by copying the djayMediaLibary database file between devices. Please refer to the linked topic below for more info:
Ok..this is very, very misleading so what is icloud used for in djay pro then?
@DJAsync as I shared above and in the linked FAQ above, iCloud Sync in djay syncs:
So, your saved cue points and saved loops.
