IOS djay pro + DDJ 400 midi map Main audio and headphone mix knobs?
I am running an IOS djay pro on IPad 9 (IOS 15.3.1) with DDJ 400
Ideally I would like to run this djay app DDJ 400 setup with a class compliant audio interface (M audio air 192/8 ) for higher quality outputs than the ddj 400 is equipped with.
Ultimately I would LOVE to retain control over the outputs of this interface from the DDJ 400 surface via midi mapping.
When I looked in the midimap menus I realized djay pro app will NOT allow recognition of the main output master knob, the headphone master volume knob, or the headphone cue/mix select knob. If you touch any of these in midi learn they do not show up at all. Every other button on the DDJ 400 does show up in midi learn. There is no midi access even if the ddj 400 and not the additional sound card is hooked up.
For reference I looked up the ddj 400 midi spec sheet online and it looks like theses knobs do have midi assignments so therefore in theory could be midi mappable. These knobs are labeled M9 M10 and M11 respectively and show cc messages and assignments.
The link for my source is on this midi implementation is:
Is it possible to gain access to these knobs via midi mapping in the djay app?
Any help on this is much appreciated. Thank you!
A post was merged into an existing topic: IOS Djay pro + ddj400 + Class compliant audio interface routing issue
