IPAD as a controller in DJAY for META QUEST
DJAY for IPAD should have an option as being used as a deck in DJAY for Meta Quest. You would use the physical IPAD as a deck and use the crossfader on the IPAD to control META QUEST DJAY application. This would make it use for professional gigs if auto mix is added in conjunction.
Thanks for the suggestion @photos_inspace. I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
Also, you may want to check out the iOS application called TouchOSC. I’m not sure if it’s compatible with Meta-Quest, but I have use this app to make custom touch screen DJ controllers on other OS’s. If you’re interested, I discuss it in detail in the linked topic below:
