What USB Dj controllers are compatable with djay using Vestax V-Midi?
So far this is the only solution regarding charging your iPad while using a USB Dj controller. Does this only work with Vestax Spin? Or can I use my Hurcules MK2?
Yes, thanks for the response Warren.
Totally understand that you canāt say anything - but am really looking forward to seeing the next development with djay on iOS and controllers will be!
Cheers.
For a controller to work with DJay 2 it would need a midi mapping within the app, as far as I know I donāt think there is one for the controller you mention - if only Djay 2 had user definable midi mappings!
Iām shocked that this topic isnāt getting more attention or none at all. Vestax has released VMIDI Controller that CHARGES your iPad & USB Controller. Does anyone know if Vestax Spin is the only compatible USB controller?
Iām glad you at least responded, though it took for ever lol. I definitely understand and Iām waiting at the edge of my seat for details. Thank you and great Job!
Ps. How do I get a job at Algoriddim Honestly, Huuuge Fan!
But Iāve also seen reports of people, who have built controller mappings within the Mac app and then after uploading it to the iDevice, successfully using them.
In fact, it was explained as accessible through the standard iTunes per-app Document repository. The same one you can download and upload files to when the iDevice is connected for syncing.
The motorized platters are not to be expected to be functional, IMO. At least not until algoriddim state. It to be supported.
Also, why would you need a vmidi for an integrated controller with a sound card. Itās goal would be to add a simple midi controller with no sound deviceā¦
This solution works for many midi controllers using Djay for iPad, and I have personally confirmed it working on these āclass compliantā ācore-Midiā devices: Pioneer DDJ-SX, DDJ-SP1, Mixtrack II and M-audio X-session WITH and WITHOUT V-midi on a iPad 3 and iPad 4, as well as an iPad Mini⦠all NON Jail-broken! Iāve even used multiple Midi controllers at once with Djay for iPad, using a powered USB hub, no V-Midi.
Sad news is that the Numark motorized controllers (not sure about the NS7II) are not class compliant core Midi devices and require drivers to work with a Mac/PC, and therefore will not work on an iPad etc. The good news is that most new Midi controllers are class compliant.
First you have to download Djay for Mac (the free demo version is fine!), then Midi learn your controller. You can map the jog wheels, cross-fader, all mixer buttons and eq knobs, library scroll and buttons, loops, and sampler buttons with Djay2 for iPad!
Then just drag and drop the .djayMidiMapping file that is generated after Midi learning from Music/djay/Midi Mappings (in your user directory) to your iPad/iPhone/iPod Touch djay app Documents (using iTunes file sharing). Yes, itās very cool that the Djay applications for different platforms use the same midi map format!!!
I tested this on iPads via the Apple CCK and a powered USB hub. The powered hub will only power the controller, not the iPad, however a fully charged iPad will let you run Djay for hours.
I have also tested using a V-Midi device which will of course power both the iPad and the controller! Had mixed results with other iPad DJ software using V-Midi but it works great for Djay for iPad!
Last point Iād like to make is that the V-Midi is not a sound card, it only reroutes the audio and acts just like a stereo splitter, providing Dual-mono. If you want two stereo outputs, one for master and one for cue, youāll have to use the powered hub option with an additional USB sound card (unless your controller has one built in, e.g. Mixtrack Pro II) and also use the built-in headphone jack for either your master/cue stereo outputs.
Many thanks to you all for contributing your knowledge. I have a love for motorised platters hence why I stated the ns7 as I intend in purchasing this unit. My iPad mini is jailbroken and would like to utilise it. Jus need a point in the right direction. But not many have tried and tested with the Vmidi. Minimal testing using camera connection kit to connect midi dj controller to ipad with additional powered USB hub! (But Vmidi is all in one). I do not own a mac book but have access to one to do the āmappingā but wouldnāt know where to start. Could this mapping be downloaded is somebody has already done it ? I would assume it has to be done for each controller. Not jus one general file. Which as mentioned I can then input the mapping file into the djay 2 app. Sound like a lot of work for the sake of motorised platter dj controller. Maybe idj pro and jus be happy? Thanks again for your input
Kaloyan: i was under the impression I could use the Numark Ns7fx (Integrated dj controller) with my ipad only. Accessing my itunes liabary on the ipad. As the iDJ Pro functions without a laptop. but the more i read, the further i get.
To confirm i have called numark, they say they do not know if motorsied platters will be functional becuase its not a test they will do (its not a controller for that purpose using ipad). you are correct. but geting it to work via mapping will
As advised before: mapping on mac and exporting the file to ios ipad will work.
looks like im just going to buy iday pro and eat humble pie as the saying goes.
