So this is my main question and is there any problem to connect a controller is it optimised for work ?
I asking because this Saturday I have a gig.
I myself have never really had a problem with the public betas. But no manufacturer will tell you that you can use their app properly with a beta. This is always at your own risk. And if you have a gig in a few days, I wouldn’t advise you to try it out either. If there are problems, it’s difficult or even impossible to go back. This won’t change even if you get positive feedback on your question from other users here. Every device and every configuration is different, so ultimately there is always a risk.
Hi @Digital_Jedi, please refer to the linked topic below:
Any update now that ios8 is official and not beta?
I am very curious as well if it is safe to update. Looking forward to Algoriddim’s response. LOVING everything you guys are doing for the last couple years Algoriddim!!!
Hi @m.law, please refer to the linked topic below. Thanks!
