📣 ANNOUNCEMENT: iOS 18 and macOS 15 Compatibility
Hi everyone!
We’ve verified iOS 18 and macOS 15 compatibility with the latest versions of djay. djay worked great in our tests with both of these new operating systems.
However, as a word of caution, there is a wide variety of hardware setups out there; so, my personal recommendation as a working DJ myself, is to stick with your current setup for now if you have important gigs coming up. Thanks!
Thanks for this very useful update @Slak_Jaw
You’re welcome @Dysfunk_DJ
Dont work well with rane performer ! (Macbook Pro M1 16 GB) Slow when loading the tracks. It hangs briefly when you first press the hotkeys
No Problems with Rane Four
Did you try the WiFi Off workaround? May be related to the same issue a few have reported…
OH without WIFI-no Problems
You can track the issue here
Thanks for sharing this @Mister_Tuur. It sounds like this issue could potentially be isolated to the 256GB models. I updated my M4 iPad Pro 13, 512GB model to iOS 18 two days ago and had no issues. I did thankfully skip the iOS 17.7 update, so that might also be why I didn’t have any issues.
Just to be sure, for everyone who’s using Files & iCloud: in 18 you can go to the Files app, pick files or folders, and select the option to keep them stored on the device. This way they’ll always be available (offline).
Thanks for the tip @Mister_Tuur
Anyone try with Pioneer FLX 4 yet?
I have a problem
I have a ddj 200
I have problem when I mixing it just either shuts off completely or djay pro ai just cuts off
I have an iPad 9th generation running iOS 18 .1 beta 5
Has been doing this for awhile
Hi @Jay_Mccollum, thanks for the information, but please note that djay does not support Beta OS versions. I recommend that you switch back to a non-beta version of iOS 18. Thanks.
Hi, i didnt work with beta !
Sorry I tagged you by accident. I meant to tag @Jay_Mccollum.
Great news. Awesome to see that you are on top of this. :+1:
Not meaning to be disrespectful in anyway, but:
Geez, are you faster than the guys over at NI - kudos!
My Mac automatically update to the latest Mac OSX, DJay seems to be working OK, I’m going to be using DJay in the weekend, I also know Im using it at my own risk, Has anyone had issues.
