Hello DJs family!
I’m looking for a way to link matching songs. So if songs go well together - I would like to link them so that I can find songs more quickly later when time is tight. Does anyone have an idea how I can do this on the MAC in DJProAi?
Thanks in advance for your support.
Greetings Siggi
Hi @DJSIGGI, this is possible on macOS. It’s called Related songs and was explained well by DJ_Big_Blender in this topic:
@Slak_Jaw
Many thanks for the tip. That’s exactly what I was looking for. Perfect. Mega! Best regards from Cologne/Germany
Siggi
You’re welcome @DJSIGGI
I am thrilled to have discovered this hidden gem of a feature and equally pleased that @Slak_Jaw has been able to share this with you also.
Have fun! Best regards from the Netherlands
Stealing from another DJ Software, I would find this - besides the still missing track suggestions from local files feature on iOS - particularly helpful:
Link songs together in a list if, for example, you have noticed that a mix or transition is particularly successful or that you particularly like. This works like your own private live feedback based on your own history and/or manually selected tracks.
Hi @koenigflo, please use search before creating new topics. I’ve merged your new topic with this existing one. This feature is already available on macOS. Please see above. Thanks!
… but not on iOS (as explained in my request), the same way that suggested tracks source from the local library is (still) not available on iOS / iPadOS
My mistake @koenigflo. Your original post was tagged as macOS. Here’s the existing suggestions for iOS:
