Is there a way to lock neural stem separation in Djay Pro so that when I add a new track to a playing track’s slot that has bass solo’d, the newly added track will also have bass solo’d? I can do this in Neuralmix the other app, but don’t see the Djay setting.
Try This:
Menu bar
top left, click ‘djay pro’
Click ‘Settings’
In the tab, ‘General’ , under the heading ‘Song Loading’,
make sure the checkbox for, ‘Reset EQ, FX, tempo’ is not checked.
There might be another setting,but can’t remember it right now.
see if that works
Actually, I’d tried that already, but the way I was going about it was having the bass on solo (neural mix button) and that button disengages solo when adding a track when that setting is unchecked. Seems like they should make that one of the things that doesn’t reset. Actually, it does work if I have the knob parameter for bass at 100 and the melodic and drums at 100. Cheers
Hi @deepspace, please update to djay 5.2.2 and turn off the following new setting:
That setting isn’t available on the iPhone version (5.2.2, iPhone 12)
Hi @Algy_Taylor, after updating to 5.2.2, navigate to djay Settings>General>SONG LOADING>Reset Neural Mix Controls. I double checked on my iPhone and it is there.
It’d help if I actually updated the software to 5.2.2, eh?
Didn’t realise the version history didn’t link up to the current version of the software you had. I do realise that now
Ha, I saw it came out right after typing it up. Quickest devs ever or you had that one ready to go.
This settings is not available on mac version 5.2
Hi @Temitope_Oyebode, as stated above, please update to 5.2.2. Thanks
Ok i will try that on my mac
