When I have an active loop on deck 1 and a song playing on deck 2, weird things happen when I use Neural Mix stuff in the middle of the loop. When the loop reaches the beginning again, the sound is audibly out of sync. It takes a short while to correct and then it is fine again for subsequent returns but it‘s slightly disconcerting and just sounds bad.
On older hardware, even weirder stuff happens: on my iPhone X, the playhead goes out of the loop until the neural mix effect sets in. Only then does playback return to normal.
Hardware: iPad Air (4th Generation)
iOS 14.1
djay 3.5.10
hit „sync“ on both songs so that the sync button turns blue
change to the faders menu
switch to the Neural Mix tab for the looped song
shortly before the end of the loop, bring the Drums fader all the way down for the looped song
When following these steps, the loop will be out of sync once it reaches the beginning again. It will then attempt to straighten this out again which sounds weird.
The two songs I’m using both come from Music.app, in .m4a format. The one on deck 1 is 13.5MB, the other one is 11.8MB. I’m of course happy to share those with you directly.
I made the video with a version from November but can confirm that this still happens with the latest version (3.6 on iOS, tested with an iPhone X on iOS 14.3).
