Manual bpm edit? Well i have the djay app from iphone and ipad and many songs have different results, and the tap button doesn’t work cos the loop function can not create a clean tempo (noises at the beginning or at the end of the looping section)
Yes i really like to modify manually the bpm and after i modify the chanche of bpm, it shows on the grid because in some tracks the bpm calc isnt accurated
Manually enter BPM.
So first of all, thank you guys for making the pitch bend option available for all iPads that support djay 2. I’m glad I don’t have to go buy a new iPad!
Anyway, this is a feature request. The ability to manually enter the BPM of a track would really be the one feature djay is currently missing that would make it pretty much perfect to me. It’s a little annoying when I want to play a track that I produced myself, so I know the bpm is, say, 148, but the analyzer thinks it’s 148.1 or 147.9 and in order to convince it otherwise, I have to try to tap it until it hits 148.0 - and even THEN it gets off, perhaps because it’s just rounding to the nearest tenth. A manual bpm field would fix this problem pretty much instantly.
I sincerely hope this is something you can include in the next update. Thank you in advance!
Manual BPM Entry.
Building off of http://community.algoriddim.com/algor… , what we need is a manual BPM entry thing.
